Still have Air Leak
david l greenberg
8,798
1
You could pull the fuse but if your air system is not asking for air the
compressor should be off. If it isn't shutting off then you may have a
problem with the pressure valve.
Dave
>How do I stop the compressor from running? Do I have to disconnect
>the
>wires?
>TW
>Thomas P. Winslow
>1977 GMC Coca-Cola TZE167V101893
>1974/75 GMC Eleganza SE TZE064V101146
>189 Hicks Creek Road, Troutman, NC 28166
>h704-528-5868 * f704-528-5868 * p704-878-1157
>E-Mail: winslow * tom_winslow
>Web Page: http://www.iredell.com
>http://www.iredell.com/gmc4sale.html
Tom,
The $99,000 question is, "Is the compressor creating pressure?". If not,
you need to repair or replace it, if so, you have a leak in the tank, lines
to the valves or in something that sees the tanks pressure.
Of course, you could have a blown out valve but that would be less likely.
Divide and conquere, check the compressor first.
Tomorrow is Free Friday on my watts line, give me a call and we can discuss
troubleshooting procedures.
Jim Bounds www.gmccoop.com / Orlando Florida
>Dave
>>the
>>wires?
>>TW
>>Thomas P. Winslow
I'm just finishing up rebuilding my compressor. Piece of cake - worst
part is taking apart the cranks and piston pins since they're locktited
with no good way to hold them still. I finally used long-nosed
vise-grips and drawfiled the marks off the crank eccentrics after I got
it apart.
I'll try to get the pic's up this weekend, but I'm planning more GMC
work.
Myrtle Beach or Bust,
Patrick
Patrick Flowers
Mailto:patri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
