squeaking
james r. muller
1
Squeaking sounds in the left front tire in a FWD. It's an Olds Cutlass
Ciera. 1987 with about 101 Thousand miles. Yeah, I agree that is a lot of
milage for a car that is only 10 years old. Well here is the problem
again incase you already deleted it. The oldsmobile. When ever I curve to
the right there is a squeaking in the left tire. It started only at 60
MPH and now it does it more often and even at 40 MPH. I just got some
messages on solutions on how to fix it and will certainly try them out
when the weather gets warmer.
And on the same car
The other problem is the gas meter, when ever you go down to about half
of a tank you can't get a correct reading. I think that this might have
been that the baffles in the tank were bad. Some people responded by
asking me how I knew it was the baffles. I wasn't 100% sure but I thought
it was. Do I need to drop the tank and put in a new one. Well, also it
has a fuel injection system. I don't think that this is the problem but
could it be that the fuel injection system is bad?
jim
