Speedo jumping
walter drew
28
Happy Thanksgiving!
My speedometer has started acting up. It jumps to 25 mph and back down to 0
on my way up to 25. Then it runs steady. Emery was over last week to
problem solve generator problems and grease the boogies which was much
easier than I thought. He said pull the cable and lubricate with graphite.
That job took all of seven minutes. Problem still exists. Your
observations would be greatly appreciated.
Problem with generator turned out that the #2 wire from the board which runs
to the kill switch inside was grounded or shorted out. No wonder the
generator wouldn't run. We called Duane for help in diagnosis. In the
process, Emery went home, started his generator and then pulled his board
and installed it on my generator. No go. That's when we called Duane. New
wire has been installed and now I can start the generator from inside. I
have had the GMC for a year and have had to jump the board every time to
start it.
I am thankful today to have Emery and this GMC net in my life. Collectively
we gather and share information and experiences without reservation. I am
taking this example of generosity into the rest of my life.
Gratefully,
Walter Drew
78 Royale
