The Tesla already offers a service to replace the battery pak. The range is 250 to 350 depending on your option.
They have a charging station halfway between San Francisco and Los Angeles. One could stop at the charging station and go to lunch while the battery is charging (about 1 hour). This is a free charge. Or you can pay $70 and they will change out the battery and replace it with a fully charged one. It takes 90 seconds.
You can pick up your charged battery on the way back home.
I have a friend in Longmont that recently bought a Telsa model S. With all the options he purchased it cost about $140,000.
What is that 7 to 14 decent GMCs?
He has the auto pilot , self parking, 240 and 120 volt chargers and other things. It has front and rear and side sensors which apply brakes and self steers to avoid collisions. It even backs out of the garage with a push of a button on a remote. After it goes off to park itself you retrieve it by pushing another button and it'll drive itself back from wherever it's parked to the place where you pushed the button. It also automatically parallel parks.
A bit pricy but it's a beautiful car and rides super smooth. 0 to 60 in about 2.5 seconds.
Emery Stora
77 Kingsley
Frederick, CO
> Matt, I knew that. The plates absorb stuff that needs to be driven out by
> charging the batteries. O.K. how about standard battery packs like a
> cordless drill. Drive in, out comes the fork lift with the fresh battery
> pack, drive off. Just a thought.
> Jim Hupy
>>> O.K. Here is one for you. Electric vehicles. Using today's technology.
>> Lead acid batteries that can be drained of electrolyte. Pull into a
>>> electrolyte changing station much like a gas station of today. Drain out
>> the discharged electrolyte and replace it with freshly charged stuff. Drive
>>> on. If we think on it, it is possible. Gasoline stations become
>> centralized charging stations.
>>> Jim Hupy
>>> Salem, OR
>>> 78 GMC Royale 403
>> Jim,
>> Sorry to tell you about this, but your plan has a weak point.
>> In current lead/acid technology, it is not just the electrolyte that is
>> depleted. The chemical composition of the plates is actually changed. That
>> is the way the technology started in the 19th century and what is amazing
>> is that there have been only minimal real improvements in all this time.
>> The fact that newer batteries have more capacity than the older did is
>> really only improvements in manufacturing processes.
>> Matt
>> Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
>> Electronically Controlled Quiet Engine Cooling Fan
>> OE Rear Drum Brakes with Applied Control Arms
>> SE Michigan - Twixt A2 and Detroit
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
