Solar Panel orders instructions
marcus mcgee
809
To answer most of the question so far:
1) Panel dimensions - 14.5"x15.5" and .75 deep
2) Panels can be hooked up in parallel.
3) I have two types of regulators, 2 Amp and 10 Amp. That means you can
hook up to 5 panels to 2 Amp unit
or a pot load to the 10 Amp unit. $15 for the 2 Amp, $30 for the 10
Amp. These have short leads on them, about 2 to 3 inches long.
4) Units must be in full sun for full 1/3 amp out put
5) They can be mounted flat on the roof. They work best if mounted at
a 45 degree angle and pointed
south, but can be mounted flat on the roof and will work well that way.
Remember they will not work well if shaded or even partially shaded.
This is
true of all solar panels.
Any one that wants some send me an email direct and use the subject line
as:
Solar Panel Order for Marcus
Put in your address that you want them shipped to. They will go UPS so
no PO Boxes.
I will enclose an invoice.
I have 17 panels, will need to check them to makee sure they are all
good ones. They should be, but I want to be on the safe side.
Thanks
