SOL-AIRE FIRE HAZARD
gary miller
452
POTENTIAL FIRE SOURCE --- I'm replacing my OEM Sol-Aire with
a Hydro-Flame. Upon removing the exhaust vent cover on the
exterior of the coach (two sheetmetal screws) I found that
the asbestos gasket that insulates the hot vent from the
fiberglass side wall had disintegrated on one side and the
fiberglass was badly scorched. I don't know how much longer
it would have been before it ignited???
For those of you who are keeping the Sol-Aire furnace you
may want to pull the exhaust vent cover (rear of the two)
and check for the continuity of the gasket....a 5 minute
job. I believe that someone else (Arch???) found that the
Sol-Aire had actually pulled away from the sleeve that goes
through the sidewall. That's BAD and easy to check at the
same time.
Gary
'77 Kingsley
North Bend, Oregon Coast
when I checked mine it had pulled away from the wall also and no gaskets at all.
>same time.
>Gary
>'77 Kingsley
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
