Slow Start
dave lowry
615
Our 455 seems to be taking longer and longer to fire up after having sat
for anything more than over night. I suspect we can fix it by having an
auxiliary fuel pump put in, but could we also fix it by having the Q-jet
overhauled?
Dave (advisor/navigator) & Dege (ALL else), '76 Royale, Santa Barbara, CA
> overhauled?
Dave,
Just a guess, but one possible cause could be fuel "draining" from the carb
float bowl ( this doesn't have to show up as an external leak ).
I would have it checked out before they install the electric pump and maybe
"cover up" the original problem.
Did you get your Onan fixed?
Peter
Colorado
>> overhauled?
>Dave,
>Peter
Maybe I could get that fixed without a full overhaul.
Onan being worked on as I write.
>YOu might also have an ignition problem. this is one of the symptoms of a
>deteriorating coil of ignition modlue or a bad ground connection on the coil.
>tom
Thanks Tom. I'll have the mechanic check it out.
Dave I have never seen a check in Qjets but someone said the fuel pump has
one to stop bleeding back to tank i use my carb filter and u get 12000 miles
on filter and i could set my watch on this
Thanks for the suggestion. I'll pass it on to my mechanic. I'm pretty sure
he'll be pulling the carb to seal the holes in the float chamber.
>Dave and Dege,
>Our coach had troubles starting and sometimes maintaining idle when cold.
>Bert took off carb and cleaned it. Just disassembled it, blew air through all
>the passages, checked the float level, and replaced the fuel filter (yes the
>one we are being told to throw away and replace with an inline one). Coach
>now fires up like a champ and idles great. If your distributor cap is old,
>you might be getting condensation in it and this could cause the same
>problem. To check, before starting the coach in the morning, pull off the cap
>and inspect for moisture. If it is warm out when you pull off the cap,
>instead of seeing moisture in the cap you might notice "dust dots" instead.
>These are caused by the moisture condensing in the cap and then evaporating
>off in the heat.
>Hope this helps,
>Bert and Fay Curtis
>'76 Glenbrook
