I've never seen this happen to the Onan 110 volt generator brushes. Maybe the Onan was operated while driving on a lot of gravel roads. Iinteresting. Bob Dunahugh
Bob,
I ordered this from Ebay (search for item 310760400781 on ebay). It has 6 brush mounts and 12 brushes, enough to do 3 generators for $35.00. The
connection appears to be a bolt type instead of a 1/4" quick connect so you may need a small terminal block.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
