The Previous Owner had replaced two sliding glass panes with plexiglass
A Passenger side small #4 and a Driver large side #2
They worked good enough until I got replacement glass from Sirum
sirumvintagegmc.com
I also purchased the replacement rubber
The original early coaches used a wire wrapped matrix that wore out leaving only the metal
I punch a hole one inch from the end of the rubber seal and use string to work the new seal into place
Plenty of soapy water too
Glass grippers also help
I use a piece of trim tile to push the rubber into place
I have the original screens for all the windows
I cut a new rubber gasket to fit between the metal catch and the glass
press the metal wiper into place
All finished with this window
Slides open and close nice and easy and fits snug into the seal
I do not have a working latch to lock the window. It was broken
I had 1/16th" shaved off of the top and bottom of the glass
This allows the new glass to fit into the frame without dismantling the coach and the whole window frame
The new rubber seal is snugger than the original and makes up for the difference (at least some of it)
Alex Sirum Vintage GMC Alex Sirum Vintage GMC Motorhomes
Your source for 1973-1978 GMC Motorhome sales, service, and parts.
