Sounds like a reasonable solution.. Unfortunately I don't have a couch to check
this out. If you know or if somebody is competent enough to tell us, could this
be done. Maybe a welding or machine shop could tell you. I don't know if you
would be loosing any strength in doing that. If it works let me know. Darren
> Darren
> First I need to apologize to all of you. I messed up. There were other
> things stacked on the couch. I only measured the couch not the arms.
> The arms do mess everything up. I can get it to you for about $220 via
> motorfreight-----again Idaho or other border state.
> I have been studying this situation to try to redeem my stupid mistake.
> If you look at the arm there is the long straight section, a bend, then
> about a 4 inch straight section. If one were to cut right in the middle
> of the 4 inch straight section and remove it then we could be back to
> my original price and UPS. When it got there you could get a piece
> of solid stock and rejoin the arms. I would like for some of you with
> a lot more experience with the GMCs to comment here. This is pure
> theory and I want it know as such.
> Take Care
> Arch 76 GB IL With egg all over my face.
> In a message dated 1/26/99 3:36:18 PM Central Standard Time,
> > You have to double the width and double the depth. This gives you a total
> > of 147 inches plus whatever type of packaging is involved. The dimension
> > can be reduced by wrapping the piece in a very heavy plastic such as vapor
> > barrier material. ( or 10 mil. I believe ) but it is still too large. The
> > only solution I can come up with is to remove the arms, but I don't think
> > this is a good idea. Check with your friend and see what comes of it. If
> > they will ship it, send it please. Darren (always calm )
