SENDING UNIT TESTING
Melbo
Member
Aug 19, 2018
155
10
18
75
I just did this. They are 0-90 ohms. Mine test from like 1 to 91 ohms.
HTH
Melbo
From my experience, the flag is set based on your IP address. Are you connecting to the internet through a VPN? Its server may be based in Canada.
As Melbo says, use an ohm meter from sensor ground to the sensor connector and read the resistance.
Bruce Hislop
ON Canada
VPN - virtual private network. Read about it on wiki.
No telling where your provider's servers are physically located on the net by IP asignment.
Tom
KA4CSG
I use alligator clips on my meter and connect to the stud on the top of the unit and clip the other one on any metal part BUT to be sure the ground
wire is good it would be best to connect to the black ground wire attached to the unit. Then just move the float up and down and watch the numbers on
the meter.
HTH
Melbo
0-90 is typical GM. Best to have meter in a manual mode probably 200 Ohm scale. Watch for dropouts./ deadspots. This is actually a great use for an
old school analogue meter.
John Lebetski
Woodstock, IL
Perhaps Texas is quietly negotiating an exit from the US and joining up with Canada? :)
> How does one test the fuel sending units?
> I've see it somewhere but don't recall where.
> I'm interested in testing the electrical part to register on the fuel gauges in the instruments up front.
> Also how to change this flag above. I like Canadians but I am an American, born and raised in the USA.
Vadim Jitkov
'76 Glenbrook 26'
Pullman, WA
