Screen door panels
mr.c
494
I am hosting the GMC roundup in Albuq, but here goes a short version. I have
only two panels and the right panel on the inside has a lip that comes inside
so it can open when I want to open the door. The outer panel is set to that
the lip in on the right side so It will close when you are on the outside.
Thus the lips of the two panels go out from the door. Does that help.
al
> I need some help/information from someone who has a screen door to tell me
> the sequence of the sliding panels! I put on a lever device on the door
> handle which protrudes inside, and it was necessary to ALWAYS slide the
> panels open before closing the door. I forgot, and panels went everywhere.
> I'm the world's worst at figuring out a puzzle and it seems every
> configuration I try isn't the way it was. (the level is coming off so it
> won't happen again)
> I need to know which side the tabs are on, lets say from the inside, and
> where the panel goes that has the double tabs. Which tab goes to the outside
> and which to the inside. Sure will appreciate your help. I need to get my
> frustration level down!!
> Justin
Don't feel too bad. I was a over a year not knowing that all the panels
slide to the left. I only found out at Forest City after I saw other
screen doors with 3 panels. Now the rattles are gone and I can open and
close the door with ease. Before it was a hassle as I slid a panel
one way to unlock the door and the other way to open the door.
By they way I don't consider myself mechanically challenged.
Richard Waters '76 PB, Troy, MI
> Thanks for the reply. Glyn and Melrose Trimble stopped by today on their way
> to Albuquerque to let me see theirs. They also have a two panel which was
> the first time I knew that some doors only have two. Mine has three, with
> one of them having double lips. (I'll blame my confusion on being left
> handed or something). Well to make it more embarrassing, the co pilot came
> along, took one look and figured it out.
> Justin
