Rusty Balls!!!
john r. lebetski
4,659
2
Jim K has the the kit but first try clean and repack with Synpower. It may work fine. There was also a thread on which balls to order from McMaster.
John Lebetski
Woodstock, IL
What is the application? Axle cv joint, steering cv joint, or muffler
bearing?
On Fri, Jun 16, 2017 at 9:24 AM, John R. Lebetski
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
Bruce, the muffler bearings are too small, after all, they spin around with the exhaust gasses to keep the muffler in perfect balance.
LOL
> bearing?
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
> Bruce Hart
> 1976 Palm Beach
> Milliken, Co
> GMC=Got More Class
”When we avoid the mistakes we might have made, we sometimes make the mistakes that we might have avoided.”
Adrien & Jenny Genesoto
75 Glenbrook 26-3
Yuba City,Ca. Text 530-nine-3-three-3-nine-nine-6
Bruce Hart wrote ojavascript:%20insertTag(document.post_form.msg_body,%20'',%20'%20:(%20');n Fri, 16 June 2017 11:17
> bearing?
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
> Bruce Hart
> 1976 Palm Beach
> Milliken, Co
> GMC=Got More Class
75 Glenbrook 26-3
My laptop played with me on the last upload
Bruce,
Last i checked, muffler bearings are too small for what his working on.
After all, they spin with the exhaust gasses in the muffler to keep the muffler in balance.
If you don't grease the muffler bearings often enough, the muffler will rust and will need replacing.
Call me if you can't find the grease fitting.
That's all folks.
75 Glenbrook 26-3
5/8". PM me your address and I'll send you 6
1977 Palm Beach, 455, mostly stock and original
Bruce asked what is the application, and I have to repeat that question.
What is the application? The original post to which John Lebetski was
responding was apparently posted on the forum by a non-GMCnet member, and
it never appeared in email form.
If it is the steering CV joint, I second the recommendation to repack with
Valvoline Synpower after removing any rust--it just may work fine. But 5/8"
is not the correct size for the steering CV joint. The correct size is
0.623", and 5/8" will bind. Ask me how I know.
Rick "who still has a box of 5/8" balls around here somewhere, but couldn't
find it last time someone asked" Denney
'73 X-Glacier 230 "Jaws"
Northern Virginia
Rick, The original poster is a GMC net member with 792 postings. You might look at your email provider as to why you missed it.
So, given that I couldn't see it, and given that nobody quoted from the
original post, I went to the forum (which I don't normally do--it took a
while to remember that login!) and I see that the original poster is Paul
Leavitt. I've searched and searched around my Gmail inbox, and I don't see
any emails from him since March, 2014. Perhaps the list owner ought to
check and make sure his forum posts are making it to the reflector,
assuming other email users also didn't see it. I checked my spam folder
(not there), and even searched all my unfiltered inbox (which is archived
back to 2010 and has 54,000 message in it), and that's what I found.
Anyway, yes, he's talking about the steering column CV joint, so my comment
is still relevant: The balls they use are not a full 5/8", but about
0.002ish smaller. I couldn't make 5/8" balls work. But I know from
experience that Synpower will work even on rusty balls, once the rust is
removed. I drove from Charlotte to NoVA with severely corroded balls lubed
with Synpower--the same balls that had made the drive down to Charlotte
most unpleasant (and dangerous)--back about a decade ago.
(I also noticed that my old registration on the forum, under user name
"Rick Denney", is disconnected from the posts I've made since 2010, which
are under user name "Richard Denney", presumably because that's how my
Gmail address is configured. Funny goings-on over there in forum-land!)
Rick "a forum member since it was a phorum" Denney
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Northern Virginia
Heck, Rick. I thought that he was jokingly referring to the rusty balls in
muffler bearings. Way I figure, it doesn't matter much what size they are.
I failed to catch the steering CV reference. Those things do matter. So
does the type of grease you lube that critter with.
Salem, Or
78 GMC ROYALE 403
> > Ken Burton - N9KB
> > 76 Palm Beach
> > Hebron, Indiana
> Northern Virginia
Yes Rick, they occasionally get out of sync. Usually this happens when someone uses a different email address. When the forum sees a new email
address from the list sever, it automatically assigns them a forum user id.
On the email list, when a new forum user appears because he posts something, the posting is sent to the email list and it bounces because the new user
is not enrolled. The bounce is sent to the admin and the admin establishes an email user id on the mail server. It use to be a manual operation. I
do not know if it still is. He has been a member since 2008 and made 8 posts in 2015, 14 in 2016, and 3 in 2017. If he was not enrolled in the
email system every one of those postings would have been a bounce going to the admin. I did not go back and look at anything prior to 2015.
Ken,
I don't see any of those post-2014 messages in my Gmail inbox. I see
everyone else's (about 25,000 GMCnet posts since 2010), so maybe Gmail just
doesn't like Paul.
Then again, every single post of Jerry Work's seems to lose the headers
that let email clients (including the forum) keep it lined up with prior
messages in that thread, so I suppose Gmail doesn't like Jerry, either.
My post counts on the forum are wacky, too. I've been largely dormant since
2011 or so, at least until recently, but I know I made more than 400 posts
between 2004 and 2010. I can't blame that one on Gmail--that was before I
could no longer use my work computer for GMCnet, which is when I got a
Gmail address to use here.
It's an imperfect pass between the systems, to be sure.
That's why I quote at least some of the message to which I'm responding--it
leaves breadcrumbs in case a pass gets fumbled.
Rick "glad some things never change :) " Denney
> ...He has been a member since 2008 and made 8 posts in 2015, 14 in 2016,
Northern Virginia
