Hi GMC'rs
My 76 Glenbrook is belching black stuff out the exhaust, the sparkers are
real black and it does not pull real hard any more.
This just started after I replaced all the Carb gaskets, to fix a vacuum
leak ( big hole in large bottom gasket), to fix transmission shifting
problem and others. Just replaced the gaskets and the inlet valve, made no
adjustments. All the jets are stock size and look tobe in good condition
(should be just about right for 5-6k feet). The choke is now adjusted so
that it Never comes on. Have had it apart a couple of times to check that
the rods are in the proper jet holes. The idle adjustment screws are at
about 4 turns, but it appears to run rich at all rpms. I have looked into
the carb when running and see no excess gas flowing. It starts when cold
just like the choke is adjusted perfectly.
Any help or clues will be very much appreciated !!!!!!
Rich - 76 Glenbrook
At the Castle in Colorado (Cloudy and raining much of the day)
Rich - 76 Glenbrook
