Read here
http://gmc49ers.blogspot.com/2017/08/the-forever-gmc-onan.html
Gene
> No need for either or. Use the same logic and process as described in the
> presentation called “Feeding the barbarian” which you can download from
> GMCMI, GMCWS or GMCCascaders and you will be able to run it from either
> propane or gasoline, likely with the flip of one toggle switch. Check with
> Honda to see if they altered the timing or compression if this was a
> factory propane unit. Check with propane conversion suppliers like US
> Carburetion in WV to see if they recommend any modification other than the
> dual induction. I have never heard of anything like valve damage from
> running propane but if so, there sure are a lot of motor homes and fifth
> wheels running around out there with generators of all makes and sizes
> happily purring along on propane that will be greatly surprised.
> Jerry
> Jerry Work
> The Dovetail Joint
> Fine furniture designed & hand crafted
> in the 1907 former Masonic Temple building
> in historic Kerby, OR
http://jerrywork.com
> Message: 2
> Date: Fri, 23 Feb 2018 18:18:11 -0700
> From: Jon Roche
> To: gmclist
> Subject: [GMCnet] Running honda ev4010 on propane
> Message-ID:
> Content-Type: text/plain; charset="utf-8"
> Wondering if anybody has been running honda ev4010 in propane?
> I always hear that propane is better however i read somewhere that
> pinella's power claims it ruins the honda valves??
> I have come accross a couple used units that are set up for propane.
> There is cost to convert back to gas, but i am still wondering on any
> damage
> that may have been done by propane? Or if i would maybe stick with
> propane.
> Jon Roche
> 75 palm beach
> St. Cloud, MN
Alternator Protection Cable
