Bob, my advise would be to leave the drip rails alone. The end pieces are
frequently sources for leaks, and can be easily removed. They contain a
rubber moulding that frequently will be deteriorated. If they are at all
usable, I use 3M 5200 and seal them back onto the coach. The drip rails are
a bitch to remove, as there are many screws holding them in place. They are
usually sealed down to the coach with a black butyl non hardening sealant,
and if they are not leaking, I leave them alone.
Salem, Or
78 GMC ROYALE 403
> Need a change of pace from the interior rebuilding for a bit.. So I got
> out the power washer. And climbed onto the roof for some cleaning. There is
> an aluminum extrusion that is were the side walls meet the roof. I had dirt
> being washed out from between the roof, and that extrusion. No leaks
> inside. But would it be a good idea to seal that seam anyway as an extra
> precaution?. Or as to leaks there. Did I just get real lucky. Best to be
> lucky, then good. Bob Dunahugh The Puzzle Mobile
