Hello:
My current project is trying to wire up a 2-way GMRS radio in our coach. There's an antenna that is mounted on the roof just behind the front seats
which I thought was installed from the previous owner so I was looking for a way to hook to it or where it runs to inside the coach. Then it struck
me that maybe it is actually just the FM antenna but I can't recall if our GMCs have a whip antenna for FM, or if it was integrated to the frame. ?
Second question, if I need to install a new antenna, where are some good spots to put it so that I can run the wire in and up to the front of the
coach (radio is to be mounted under the front dash)? One idea was mounting to one of the mirrors and run the cable in. I'd prefer it on the roof and
out of the way, but each spot I've considered so far has its challenges on how to run the wire in and over to a wall and up to the front. I'm curious
what others have done for roof antennas.
Thanks in advance!
Chris
Chris S. -
77 Kingsley, 3.70 FD, mostly OEM -
S.E. Michigan
Thanks in advance!
Chris
Chris S. -
S.E. Michigan
