Rivets for rear roof cap, corner
who_dun_it
Member
Dec 21, 2008
180
16
Hi All - I am missing two rivets at the right rear corner of the roof cap. Where do I purchase the rivets? Will I need to take down he ceiling to put
on backing washers?
Thank you
Les
T.O. CA
Is the entire rivet missing? If it is then take a piece of wire put a
small 90 deg bend on the end to determine the total thickness needed to the
correct rivet length. I would suggest the following rivet from McMasters
Carr.
https://www.mcmaster.com/rivets?ref=driverlayer.com
The Rivet does not require a backing washer.
J.R. Wright
GMC Great Laker
GMCGL Tech Editor
GMC Eastern States
GMCMHI
TZE Zone Restorations
78 Buskirk Custom 29.5' Stretch
On Location in Tucson
On Sat, Dec 21, 2019 at 7:06 PM Les Leach via Gmclist <
> on backing washers?
> Thank you
> Les
> T.O. CA
John,
Can you describe them in more detail, or provide a McMaster product number? The link just brings up “rivets” in McM’s web page. I have never found rivets with as big a head as the originals in that spot, but I need them, too.
Rick “thinking the McMaster web page doesn’t put full URL’s in the URL window when looking at a product” Denney
Sent from Mail for Windows 10
Sent: Sunday, December 22, 2019 12:07 PM
To: GMC Net; John Wright
Cc: John Wright
Subject: Re: [GMCnet] Rivets for rear roof cap, corner
Carr.
Carr.
J.R. Wright
The rivet is 3/16" diameter, the flanged head is 5/8" diameter. Part of the rivet is still in place so I can not push a wire to the full length. I
think I will take the inside cap down before I do anything else. It looks like the head of the rivet is larger than a regular pop rivet.
Les
There are pop robots that have slits thstbecpand as much as 5/8 dia. So it
works well without hassle.
Should you have issues locating them then let me know.
On Mon, Dec 23, 2019 at 6:30 PM Les Leach via Gmclist <
> Carr.
> J.R. Wright
> Les
http://www.appliedgmcrvparts.com
Thank you
> Les,
> Large head rivets
> https://www.airpartsinc.com/Large_Flange_Pop_Rivet.htm
> Olympic rivets have slotted shafts and the legs open up to increase the bearing surface on the backside.
> https://www.airpartsinc.com/Olympic_Shaveable_Pop_Rivets_5-32_.htm
> The head shaving tool is really slick but I've never been able to rationalize buying one.
> https://www.airpartsinc.com/SHAVER_TOOL_FOR_OLYMPIC_RIVETS.htm
> Richard
Finally remembered that I needed to come back to this item. Thank you for the information
Les
