If we are addressing the bearing that is attached to the hanger, there is
no seal there as the bearing is a sealed bearing.
However if your needing one that is attached to the Final drive
case.it is
a double lip seal.
We stock All and any parts for the coaches.
We are now facing Back Orders on lot of the parts.
Even the ZipDee awning are on back order.
> > Anyone know where you can get replacement bearing/seals for the right
> inboard shaft attachment bearing that rides in the bolt on bracket outboard
> > of the differential?
> Sandy,
> Did you call GMCRV parts (aka Applied, aka JimK)?
> Matt
> Matt & Mary Colie - Chaumière -'73 Glacier 23 - Members GMCMI, GMCGL,
> GMCES
> Electronically Controlled Quiet Engine Cooling Fan with OE Rear Drum
> Brakes with Applied Control Arms
> SE Michigan - Near DTW - Twixt A2 and Detroit
Jim Kanomata ASE
http://www.gmcrvparts.com
