Ride height specs
thom hole
212
Hello, I have '78 Transmode that's been converted to RV Use. While jacking
up the Left rear of the vehicle(to replace a broken Shock Absorber) the
linkage that operates the Ride height valve Pulled the valve off of the
vehicle. I have reattached it but now I do not believe I have it set
correctly. After AUTO leveling finishes, The left side is higher! What is
the proper height? It also tore off the air line to the air bag. I
have fabricated a makeshift connection but will see about getting the proper
fitting from somewhere on Monday. Any Advice would be appreciated as I
have owned this vehicle for 8 days!!! Thx............TH in North Carolina
MY address is
Thom Hole
c/o Cisco Systems
7025 Kit Creek Road
Research Triangle Park, NC 27709
Workday Phone (919) 472-3975
Thanks in advance........th
>Thom:
>I had a similar experience while replacing a shock. I used a fiberglass kit
>to repair the inside of the wheel well and reattached the device. I have
>manuals that show pictures and instructions for setting the proper level.
>Unfortunately I don't have a scanner but if you want to give me your snail
>mail address, I'll be glad to Xerox the pictures and instructions and send to
>you. It really isn't very complicated.
>My wife and I are going out to dinner in a few minutes. When we get back I'll
>check the instructions and if I think they are sufficient wihtout the
>pictures, I'll type them up and send by e-mail. If you don't hear from me
>over the week end, you will know that I think they need to be mailed.
>Justin Hill
>I attempted to send this direct to you but it wouldn't go through. Guess I got
>the address wrong
