Remove the brake booster from a '78
Matt Colie
11,101
807
113
South East Michigan near DTW
Does anybody know a practical method to remove the booster from a '78??
I have been tasked to remove the booster of the parts coach in my back yard.
After a very short appraisal, this looks like I either have to remove the whole instrument panel or bore holes in it.
I am trying to not destroy any parts that may be of value to someone else.
Thanks
Matt,
If you carefully cut away the plastic of the dash where it joins the
firewall horizontally beneath the booster, you can reach the lower two
bolts. The missing plastic isn't obvious unless you're laying on the floor.
I don't remember how you get to the upper two bolts on the 77-78 w/o the
removable leveling switch panel.
> yard.
> Thanks
> Matt
Matt,
Here is the pictures on how to get to the bolts on the booster.
http://www.gmcmhphotos.com/photos/bob-dunahugh/p60045-brake-booster-nuts-in-2777-and-2778-gmcs.html
and
http://www.gmcmhphotos.com/photos/bob-dunahugh/p60044-brake-booster-nuts-in-2777-and-2778-gmcs.html
John
> Matt,
> Ken H.
>> yard.
>> Thanks
>> Matt
>> GMCnet mailing list
Read here
http://bdub.net/gmcmotorhome.info/booster.htm
> Matt,
> brake-booster-nuts-in-2777-and-2778-gmcs.html>
> and
> John
> > On Oct 24, 2016, at 10:54 AM, Ken Henderson >
> > Matt,
> floor.
> > Ken H.
> > On Mon, Oct 24, 2016 at 10:45 AM, Matt Colie >
> >> yard.
> the
> else.
> >> Thanks
> >> Matt
> Arms
> >> GMCnet mailing list
Alternator Protection Cable
The upper two fasteners can be accessed by removing the instrument bezel,
heater controls, and radio. More of a tedious exercise than a difficult
one. Done a few of them. Early coaches can be accessed by removing the
leveling controls. Not a fun job by any means, either way.
Salem, Or
78 GMC ROYALE 403
> Matt,
> and
> John
> > Matt,
> floor.
> > Ken H.
> >> yard.
> the
> else.
> >> Thanks
> >> Matt
> Arms
> >> GMCnet mailing list
Emailed you Matt, I did mine from underneath with a few careful relief cuts.
77 Royale, Rear Dry Bath. 403, 3.55 Final Drive, Lenzi goodies, Patterson carb and dizzy.
Mid Michigan
Matt,
I got to frustrated with trying to get those top two bolts out, so I cut a hole in the dash big enough to get my hand through. Then made a friction
fit plug for the hole. Fastened a piece larger than the hole to the plug and upolstered it to match the Dash. Now when I need to get at those 4
bolts, I pull the friction fit plug, and loosen them with a 3/8 drive ratchet and stick my hand in here and finger back them out. The plug looks like
it belongs. Works for me. JWID
Larry
78 Royale w/500 Caddy
Menomonie, WI.
you can get at them from the inside laying on the floor by the accel pedal and reaching in above the 2 bols that were openened up with the removal of a piece of dash....inside the booster is a rubber diaphrame....this can be replaced by a reputable brake shop...so you have all the same parts as before.....brian 77ele 455 near wpg
Sent: October 24, 2016 9:11 AM
Subject: Re: [GMCnet] Remove the brake booster from a '78
Salem, Or
78 GMC ROYALE 403
> Matt,
> and
> John
> > Matt,
> floor.
> > Ken H.
> >> yard.
> the
> else.
> >> Thanks
> >> Matt
> Arms
> >> GMCnet mailing list
WHAT??????you can reach in there on a 77 ele....brian 77 ele
Salem, Or
78 GMC ROYALE 403
> Matt,
> and
> John
> > Matt,
> floor.
> > Ken H.
> >> yard.
> the
> else.
> >> Thanks
> >> Matt
> Arms
> >> GMCnet mailing list
Yes
I've done it on my 77 Kingsley.
If I remember right I used a u-joint on my socket wrench.
Emery Stora
> From: Gmclist on behalf of James Hupy
> To: gmclist
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
>> Matt,
>> and
>> John
>>> Matt,
>> floor.
>>> Ken H.
>>>> yard.
>> the
>> else.
>>>> Thanks
>>>> Matt
>> Arms
>>>> GMCnet mailing list
>>> GMCnet mailing list
>> GMCnet mailing list
> Yes
> Emery Stora
Same here. I was able to replace the booster on my 1976 Palm Beach WITHOUT having to cut anything. As I remember I used 1/4" drive u-joint socket
and also an appropriate size 12 point box end.
