>GMCers
>Some time back I mentioned the idea of putting a computer fan
>in the vent over the reefer. Some concern was expressed about
>the heat it would be exposed to. So I thought I had better do some
>more research. The Tech America fan #900-2514 has a design
>temperature range of-22 to 170 degrees F. They are ball bearing
>fans not the bronze sleeve type.
Arch,
you might want to ask them for the MTBF for the fan at various temps. I
consulted to a company that makes CPU fans and know from that experience
that different fan manufacturers have vastly different MTBFs. From what I
saw of actual failure rates, a good sealed ball bearing fan will
significantly outlast a sleeved fan.
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
Arch,
Henry
fax: (831) 462-5198
