All,
Just purchased my 1975 Eleganza II in late May. I'm working to stop water intrusion issues before taking it out for weekend journeys. I've removed
the Driver's side drip rail, and in the process twisted the heads off of four screws. At some point in history a PO removed/resealed the drip rails,
which is evidenced by the fact that the screws I removed were non-stainless steel countersunk head style screws(#10-20).
To clean out old sealant in the screw holes, I ran a #10-20 tap down a couple of them. I noticed that when I thread in a new screw there is a lot of
slop in the hole. I've read about sliding the drip rail down a 1/4" and redrilling new holes...mainly because of the difficulty in drilling out the
factory installed screws. Is there a reason why I shouldn't redrill the existing holes, and tap them up in size to say a #12-24 or a 6mm (which is
slightly smaller than a 1/4" machine screw)? The four broken screws would not be that difficult to drill through.
How sealant looked after drip rail removal:
http://www.gmcmhphotos.com/photos/data/7231/IMG_2416rz.jpg
Screw used by PO:
http://www.gmcmhphotos.com/photos/data/7231/medium/IMG_2473rz.jpg
Drip Rail cleaned:
http://www.gmcmhphotos.com/photos/data/7231/IMG_2460rz.jpg
Thanks,
Shane
Screw used by PO:
Drip Rail cleaned:
Thanks,
Shane
