If you know someone that might be interested. Let me know. =
This 73 Canyonland has just had the entire interior removed, refinish=
ed as needed, and reinstalled. Cabinets, and drawers have now been reassem=
bled with glue, and screws for durability. Interior of closet drawers hav=
e been sanded. And a coat of clear urethane applied for a clean surface. =
The closet had now been lined with Cedar. New modern looking counter top. =
New plywood ceiling that has a mold, and mildew resistant coating applies =
to both top, and bottom sides. Real Walnut paneling installed from the doo=
r forward. A high end cloth headliner that was used in custom built Winneb=
ago motorhomes has been installed. With 8 LED recessed light. These lights=
are controlled by wall switches. Bed area, and hall lights can be turned o=
n at front door. Then turned off from rear bed. All new under cabinet light=
s are LED's. Two Fantastic ceiling vents units in ceiling.TV coax cable, an=
d USB ports installed at front, center, and rear. Newest in electronic 110=
volt to 12 volt converter installed. More 110 volt plugs added. New window=
treatments. $2,400 spent on all cushion/seats. New water resistant floor=
ing. Built in micro wave cabinet. These next items are also new. Roof=
A/C unit, Magic Chief 4 burner cook top, Domedic frig/freezer, roof ladder=
, and a Surflow water pump. Replacement Suburban furnace. Outside paint i=
s older. But nice. Mechanicals. New 16" American Eagle rims. With D=
unlop tires. 6new KYB shocks. Both gas tanks installed with new gas tank se=
nding units. And new rubber gas line. New exhaust tail pipe. Complete 78 r=
ear suspention, and brakes installed. New rear brake hoses. Main frame is i=
n excellent condition. Cleaned, and painted. Engine oil pressure is good. C=
ompression readings are excellent. At 150 to 155 psi. All belts are new.=
Items to be completed before it's shown at the Amana rally. New ti=
ming chain/sprockets, engine water pump, and a Howell fuel injection syste=
m with computer controlled ignition system. Front wheel bearings serviced. =
This GMC will be able to travel anywhere in the country. $21,000. Bob Du=
nahugh 319-521-4891
nahugh 319-521-4891
