Okay fellows I need your help, especially the engineers who have the
hard data and know the physics. Here's the hypothetical problem:
Suppose I have four tires, all either E range or all D range. Two of
them are in "fair" condition, and two are in "better" condition. I am
refering to side wall conditont more than tread depth. Should I put the
"better" condition tires in the rear wheel position or not?
Don't suggest putting any of them on the front, as in my hypothetical
case the wheels on the front are a different size and different wheel
studs etc.( Just want to close that solution completely)
What I am trying to get at is--where is the fulcrum point when one
turns? The myth, and maybe fact or maybe not, is that the fulcrum point
would be at the mid wheels and therefor as one went down the road and
when one turned corners, there would be greater side to side forces
exerted on the rear sidewall tires than on the mid sidewall tires.
If this was then true, I would presume it would be prudent to put the
better tires in the rear wheel position and the poorer ones in the mid
position. Again I'm presuming that at the fulcrum point there is less
side to side force exerted than at some point behind it. Now for all I
know maybe the fulcrum point is half way between the mid and rear wheel.
Don't tell me that I didn't want to hear that. Maybe that isn't even
possible, however maybe it is the pivet point.
Waiting for the facts and not myth
Claude in Victoria
Claude in Victoria
