Now you're making me curious. I'll have to look at the board and see what I can see in the circuit...Just guessing, but the forward voltage drop of a red LED is about 2 volts, so I would say each vertical column of 4 leds are in series with current limiting then the 5 columns are in parallel. Or it could be by the row of 5 LEDs x 4 rows. In either case, one failed LED in series will take out the rest in series, but still leave lots of operational LEDs.
Same with the backup LEDs below.
