The best device I have found to use for fastening items to the coach are
a item called a rivet nut. I went to my local bolt and screw supplier
and they are available in several sizes 6-32 to 5/16-18. They come in
steel and aluminum materials. Eastwood also sells a blind threaded
insert that I have use also. Their site is:
www.eastwoodcompany.com. It
is on page 74 of there latest catalog.
J.R. Wright
GMC Greatlaker
Michigan
> In a message dated 10/11/99 7:50:12 PM Central Daylight Time,
> > What was the thingy that went into the camper and grabbed then swelled
> > and
> > held the ladder on? I read it here but can not fine it in my notes. Could
> > someone tell me again.
> Bryan
> Its called a molly. You can get then at most hardware stores. The
> trick is to get the ones with the right amount of reach. Now I have
> had real good luck also getting them at NAPA. The problem
> with hardware store mollies is that most of them are meant to go
> through 1/2 inch dry wall. they will never pull up tight. Napa has
> one for mounting side mirrors ect. They also have one painted
> white that they said was for a Chevy Van. I have no idea what it
> is used for but thats how I mounted my grab bar by my entry door.
> Take Care
> Arch
