> Gang, Trying to get the jump on the upcoming rear disc retro
> and waswondering how, aside from a quart of PENETRATING OIL, a
> JOHNSON BAR AND A SERIOUS IMPACT WRENCH, one removes the bolts
> holding the hubs to theoriginal drums?
Yep - that's the *fun* part. I laid one of the tires down on the pavement
and bolted the hub to the outside face of the wheel using two lug nuts
tightened down from the backside of the wheel. Then used a half inch drive
breaker bar with my "cheater"(4 foot piece of chromoly steel tubing - works
like a big spring), put as much weight as I could on the tire and pulled.
Once I got the the bolts broken loose, my tired on B&D impact wrench would
spin them out.
Let me know when you get ready and I'll run up to Norcross to help. BTW,
I'm still bleeding my brakes. It's tough(understatement of the day) gettin
all the air out of a completely new brake system on this coach!
Patrick
spin them out.
Patrick
