Rear Bearings
jim bounds1
2,066
David,
What do you need to kow? You've got the right #'s, I would, of course,
change the seals. The # for them is 8974S.
Call if you have any questions,
1-877-275-4462
Jim Bounds
>I need to replace the rear bearings on one wheel at least. The no. on the
>outer bearings is 15103S which agrees with the no. in the parts book. The
>inner bearing is an NDH LM501349. The book shows # 150269 for the inner
>bearing.
>Can someone give me a alittle advice?
>David
Jim Bounds/Co-op Motor Works Orlando www.gmccoop.com
