Hi Vic;
If you use this set up, don't forget to also properly support the
coach with jack stands too, especially in the rear to guard against a sudden
loss of airbag pressure. Its always good to be on the safe side even if
there would be a lot of clearance while on the ramps. Case in point, I am
looking at a Toronado next week that fell off the jack the owner was using
while he was under it. His widow is the one selling me the car. Take care,
walter bright, 76 GB
- -----Original Message-----
Sent: Thursday, September 23, 1999 1:06 AM
To: gmcmotorhome
Subject: Re: GMC: ramps
Vic
I may have been the source of the 2x10 ramps. I use them to level out my
trucks at show
siites.
To build an easy one, start with a 10 ft length. Cut one length 4 ft long,
one 3 ft
long, one 2 ft long and that leaves you one about 1 ft. Stack them up so
that they
graduate with one end flush. If you are in a hurry, nail them together, but
if you want
them to last, take the time to screw or bolt them together.
That takes care of one side. Now repeat, and you have a pair. Place them
behind the
rear wheel and drive up on them (after removing your "T skirts"). It gives
you enough
room to do a lot of work under the rear.
If you make two sets, you may be able to place them behind both the front
and rear tires
and drive up on all four. Make sure that you have someone checking that you
dont' drive
back too far and drive off the back. That could mess up a lot of nice body
work.
But, it you do it right, it raises the whole coach about 6 inches. That's
how I
installed my macerator pump, etc.
Have fun....
Wayne Newland F9300 75 Palm Beach Columbia, Md
> I have 2 x 10 ramps which I build per specs from some good person on this
net . . .
> Gil: where are the specs located. I would like to get a set built.
> Vic
> Vancouver, BC
