Hi folks.
I'm trying to determine tranny fluid flow in an effort to improve cooling at
low speeds.
Is the reason for increased pan temperature in stop and go traffic because
of no cooling air flow or because not enough tranny fluid is being
circulated through the cooler?
I'd like to think it's because of insufficient air passing over the cooler
fins as that's an easy fix (add a fan) but thought I'd ask first.
Another question is whether coolers such as the Perma-Cool actually have a
thermostatic control in them so as to allow fluid to get up to normal temps
or are they always in full cooling mode?
I currently use a passive external cooler without any fluid passing through
the radiator. The reason being that it was thought that it could not be
sufficiently flushed to assure all metal would be gone from prior tranny
failure.
TIA for your comments
Heinz
low speeds.
failure.
Heinz
