Just curious if anyone has installed a pusher fan and had positive results?
It’s been a very hot summer here and I have noticed that my temps have crept up on a few runs on extremely hot days. Mostly on big hills/mountains
such as in the Quebec Laurentian’s.
I have noticed that in extreme conditions my 2 year old Sanden will start to squeal intermittently. I really don’t want to blow that baby apart. It
is doing a fantastic job of keeping the 78 nice and cool. Thanks to Jim K, Applied and this forum I DIYed the AC a couple years back and so far so
good.
My H20 temps usually hold steady at 190 but it has moved over 200 in extreme weather. I have gauges on trans fluid, motor oil temp and diff temps.
It’s a bit unnerving to watch those three creep up, that’s usually when you may hear the odd squeal.
I believe my rad is in tip top shape as the PO had it record when he installed a DP 455.
I also have a new old stock Griffin Rad that is slightly damaged. I haven’t taken it anywhere to have it tested as of yet.
On the Griffin note: is there a brass fitting kit that is required for the Griffin rad?
Thanks in advance...
Jim Owens,
78 Royale,
Out skirts of Kitchener, Ontario
good.
Jim Owens,
78 Royale,
