When you open the small bleeder valve, one can always put in some LPG.
Never use a steel object as it can cause a spark. Use a brass or Aluminum
rod and strike the ball in the nossel and loosen the stuck ball, or take a
large screwdriver handle and strike it hard few times to break the ball
loose.
> Larry,
> You are probably 100% right. Maybe it can’t accept any more propane
> because it could be at its max.
> Just as a example, I use about 5 gallons(pounds?) a year. That is
> Glamping(full hook ups) about 100 days a year. With a tankless water heater
> with 2
> people taking extra long showers each day. And propane for the fridge
> while traveling. No propane stove or cooktop.
> These things really don’t burn much.
> Have fun in New Orleans! We will be passing through there later on in
> April.
> Scott.
> Scott Nutter
> 1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final
> drive, Quad bags, tankless water heater, everything Lenzi. Alex Ferrera
> installed MSD Atomic EFI
> Houston, Texas
http://www.gmcrvparts.com
