Before we run too far down this path, we should consider the other sides of
this.
1 I do not know if it works. It would be good to have some solid data,
but we do not at this time. Most of the claims are hard to prove.
2 The propane is on all the time, there are special safety valves, but I
know some of you do not leave your propane on all the time. I do for the
refer.
3 There is some complexity, a propane run to the front of the coach,
valves located in the engine compartment,and switches to the driver area.
I believe the vendor will install this system and they are located in
Sacramento, CA. Osborn in NM also installs these systems.
gene
>OK here goes. There is a special fitting on the tank that is a safety
switch. In
>the event that gas runs faster than normal (ie if there is a break or
breach in any
>of the propane lines) the flow of propane is stopped. A special hose runs
from the
>propane tank to the front where there are two solenoids installed. Both
are on
>switches. One allows a small quantity of propane to go into the carb
(EFI) as a
>vacuum sucks it in. You still use gas but the propane is to ensure a
clean burn and
>lower carbon buildups. The second solenoid is connected to a switch to
turn it on,
>plus a vacuum setting that senses when the vacuum gets down to a set
level. Mine is
>set around 7" and if the vacuum drops down and if the switch is on then a
higher
>concentration of propane is brought into the vacuum of the carb (EFI).
This amount
>is set by the orifice that you specify when you install the system. The
larger the
>orifice, the more propane you inject. Thus it helps when you are climbing
hills or
>needing more from the engine. Otherwise the second solenoid does not come
on. The
>first one can be left on and it lets in just a small amount.
>hope that helps.
>al
>> Ok Al or Gene. Who knows enough to do this set up for you or is a
simple thing I
>> could do? Where do you store the propane or do you run the line clear
from the
>> end
>> of the GMC's household propane, e.g. refrigerator and heater?. Chuck
>> > Do you use the propane as an additive to the gasoline or do you use
strictly
>> > propane. I wish you would have shown this off at the rally. Things
like this
>> > are of value and interest. I do know that if you use propane it
must be
>> like
>> > a tank for our other propane uses. What is the weight differences
between the
>> > propane and the gasoline? I see there are lots of commercials going
to natural
>> > gas including a lot of the government on Vandenberg AFB. What kind of
mileage
>> do
>> > you get with your set up. Hanna and I got 10. even pulling and using
roof air
>> > coming to NM as we did not have dash air. Emry fixed that for us and
we have
>> not
>> > calculated the total trip yet. She goes into the hospital tomorrow.
See ya
>> > Chuck
>> > > > Arch
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
