Powermaster test rig Amana
john r. lebetski
4,659
2
Bob Stone twisted my arm to bring the Powermaster test rig to Amana. We can do informal testing near my coach. Can look at Amp draw, pump run time,
on/off pressure set points, confirm pump check valve, check accumulator reserve, and look at MC output pressures. Only attending Sat-Mon. If you want
to test a Powermaster please bring your own fresh quart of DOT 3 and take away same used fluid. I have a catch pan, funnel and fine mesh filter to
filter particulate matter as we go.
John Lebetski
Woodstock, IL
To John L.:
I brought mine to be tested at Bob Stone’s suggestion. It’s in a cardboard box!
Mike Kelley
Mike/The Corvair a holic
Sent from my iPhone
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Hi John L.:
In site 31 - white 76 Eleganza II w/ green trim (Topica Graphics special paint job) w/ Blue 65 Corvair coupe as toad, and tow dolly sitting under tree!
Peoria, IL. - summers and fall
Sent from my iPhone
> Ok. I'll look for ya there.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
