Powermaster brakes and adapter for sale
bob mclaughlin
979
Tom,
Why did you decide not to use the Power Master? I am interested in the
Power Master if it improves all six brakes and not just the rear drums. Let
me know how much you need for the complete kit.
Thank,
Bob McLaughlin
beverly
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of Tom Warner
Sent: Thursday, March 02, 2000 1:59 PM
To: gmcmotorhome
Subject: Re: GMC: Powermaster brakes and adapter for sale
I have decided not to use the powermaster setup on my coach and have a new
one for sale including the special adapter made my Mr. Peck. I will sell it
for what i paid for it. It was bought by thom Hole for me and has a
lifetime guarantee thru auto advantage I believe. If anyone is interested i
will dig out the paper work and figure out the price. If I remember
correctly it was about 1/2 as much as one purchased here in new york.
Bob:
If you want to improve your stock dumb brakes, get a couple of sets of
CARBON METALLIC, that's right carbon metallic, brake shoes! Give
Buskirk-Rush a call and ask them they will know whwt you are asking for.
Tim
[mailto:owner-gmcmotorhome]On Behalf Of Bob Mclaughlin
Sent: Thursday, March 02, 2000 6:13 PM
To: gmcmotorhome
Subject: RE: GMC: Powermaster brakes and adapter for sale
Tom,
Thank,
Bob McLaughlin
beverly
you might want to read the stuff on my web page about Powermasters.
gene
>Tim,
>My stock dumb brakes have carbon metallic pads on the front and large
>diameter wheel cylinders on the rear plus the usual maintenance items. The
>rear tandems will lock up on a panic stop below 5 mph. None of the wheels
>will squall and smoke on a panic stop from higher speeds. I've had it
>tested by experts and they work just like all the GMC's. That's not good
>enough for me pulling a Toad. The larger front calipers may be my next step
>but I'd like to hear all sides of the Power Master story as well. I hope
>everyone keeps the info flowing.
>Bob McL
>From: owner-gmcmotorhome
>[mailto:owner-gmcmotorhome]On Behalf Of Peg
>Sent: Thursday, March 02, 2000 6:00 PM
>To: gmcmotorhome
>Bob:
>Tim
>To: gmcmotorhome
>Tom,
>Thank,
>Bob McLaughlin
>beverly
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Tim,
Bob McL
To: gmcmotorhome
Bob:
Tim
To: gmcmotorhome
Tom,
Thank,
Bob McLaughlin
beverly
On Fri, 3 Mar 2000 12:21:33 -0600 "Bob Mclaughlin"
snipppppp
> good
Bob, have you considered a brake for the Toad?
David Lee Greenberg
The GMC Motorhome Registry
Dedicated To The Classic GMC Motorhome
www.gmcss.com/registry.htm
David,
I got to look at Byron Maxwell's setup of his Tracker and he used a surge
brake that he said works well. I purchased the same thing and haven't had a
long enough trip to test it properly. I think it will be okay. I learned
to drive 55 years ago using mechanical brakes and my Dad said if I
anticipated things right I shouldn't need to rely on my brakes. That was
okay then but I'm spoiled now and I want to see them smoking and hear them
squalling in a panic stop. There's a lot more traffic to anticipate
nowadays.
Bob McLaughlin
davegreenberg1
Sent: Friday, March 03, 2000 2:33 PM
To: gmcmotorhome
snipppppp
> good
David Lee Greenberg
Bob:
I guess I did not make myself clear. Yes, front carbon metallic brake pads
have been in use for some time and work very well, especially when heated
(used hard). What I was referring to is there is now available carbon
metallic brake shoes! ( brake pads are used with rotors: brake shoes are
used with drums ) Therefore my suggestion was to get Two sets of carbon
metallic brake shoes for the rear wheels to go with the front carbon
metallic brake pads. This would seem to me to be a more economical solution
to improve braking capability than to expend many more $ on converting to a
disc rear set up. Just a suggestion as there is no substitute for defensive
driving.
Tim
Sent: Friday, March 03, 2000 1:22 PM
To: gmcmotorhome
Tim,
Bob McL
To: gmcmotorhome
Bob:
Tim
To: gmcmotorhome
Tom,
Thank,
Bob McLaughlin
beverly
Tim,
I guess I had my head in the sand. I didn't know there were Carbon Metallic
Shoes as well. That's a much less intrusive mod to the rear brakes than
going all the way to discs. Thanks.
Bob McL
Sent: Saturday, March 04, 2000 8:20 AM
To: gmcmotorhome
Bob:
driving.
Tim
To: gmcmotorhome
Tim,
Bob McL
To: gmcmotorhome
Bob:
Tim
To: gmcmotorhome
Tom,
Thank,
Bob McLaughlin
beverly
>Bob:
Who makes the carbon-metallic brake shoes for the GMC?
What are the part numbers and the cost?
Dave
Ann Arbor, MI.
73 Sequoia (26'/455/EFI/HEI/160=B0)
On Fri, 3 Mar 2000 20:28:31 -0600 "Bob Mclaughlin"
> David,
> surge
The surge brake will do the trick but I am partial to the vacuum brake.
The only reason is I can back up with the vacuum brake as long as the
Toad's wheels are reasonably straight. The few occasions when the need to
back up a few feet has made me a vacuum brake supporter.
David Lee Greenberg
David,
I never thought of the backing problem. I assumed that with 4 wheels down I
wasn't skillful enough to back up anyway but 4 or 5 feet might be important.
I'll just rationalize and say I'm backing up to check my Toad brakes.
Thanks for the thoughts.
Bob McL
davegreenberg1
Sent: Sunday, March 05, 2000 8:14 AM
To: gmcmotorhome
> David,
> surge
David Lee Greenberg
> David Lee Greenberg
I have a utility trailer that has "surge brakes" and it has a locking pin
that you can use to disable the brakes. I use it when I'm backing up.
Of course you have to get out and set it, but if backing up a with a
toad is an occasional thing, what would be wrong with that?
Of course I don't know if that type of brake is available for use with
toads. I just assumed you could if for for pulling a car.
Richard Waters '76 PB etc.
IIRC...
you cant use the P-30 Master Cylinder w/powermaster unit and you need it if you have the 80mm calipers.(Especially on mid axle too??)
Correct me if I'm wrong...
CBWood
77 Kingsley
MWC OK
(on 'Digest' now)
Get free personalized email at http://www.switchboardmail.com
The Carbon-metalic brake pads are Performance Friction #0524 and are
available at auto zone and most large chain auto part stores. Under #35
for the set.
J.R. Wright
GMC GreatLakers
Michigan
> Dave:
> Give Buskirk-Rush a call, they for one I know of can supply you with th=
e
> particulars. My understanding is the hotter the brakes get the better t=
hey
> work, within reason of course!
> The part that is the best is they are a real improvement and cost a who=
le
> lot less than other alternatives.
> Tim
> [mailto:owner-gmcmotorhome]On Behalf Of Dave
> Sent: Saturday, March 04, 2000 8:01 PM
> To: gmcmotorhome
> >Bob:
> >I guess I did not make myself clear. Yes, front carbon metallic brake =
pads
> >have been in use for some time and work very well, especially when hea=
ted
> Dave
> Ann Arbor, MI.
J.R. Wright
GMC GreatLakers
Michigan
