Power to Starter
arthur mansfield
290
I was trying to check out the isolator and tried to start the motor. I found I am not getting any voltage down to the started when I try and start the motor. Is there a relay in the dash or is the problem in the key or shift level.
I guess my RV has seen better days. When chasing the wire to the started I found it need to be replaced as the insulation has started to come apart under neath. Fortunately the wire is not touching anything.
Art
You might want to check the neutral rod on the lower steering column and
loosen the screws and see.
> shift level.
> Art
http://www.appliedgmc.com
Art, do not lose hope. Battery cables are a maintenance item. THE VERY,
VERY FIRST THING YOU NEED TO VERIFY IS VOLTAGE AT THE BATTERY THAT YOU USE
FOR STARTING THE COACH. IF IT IS LESS THAN 12.25 VOLTS WITHOUT A LOAD,
CHARGE IT. UNTIL YOU ARE WORKING WITH A FULLY CHARGED BATTERY, YOU WILL BE
UNSUCCESSFUL AT TROUBLE SHOOTING ANY PART OF THE ELECTRICAL SYSTEM. WHEN
YOU HAVE A FULLY CHARGED BATTERY WITH GOOD CLEAN CABLES CONNECTED
CORRECTLY, THEN COME BACK ON THE NET SO WE CAN HELP YOU.
JIM HUPY
SALEM, OR
78 GMC ROYALE 403
shift level.
Art
I checked the battery voltage does not change when I try and start the motor. I even tried to add the house battery and no help. I am just glade I check to see if power was getting to the starter before I pulled the starter.
> JIM HUPY
> SALEM, OR
> 78 GMC ROYALE 403
> shift level.
> Art
I changed the tilt on the searing column and the started engaged. The column was full tilted up. Now it is straight Jim’s comment about the neutral rod made me try the column first.
So what do I need to fix.
Thanks
Art
>> JIM HUPY
>> SALEM, OR
>> 78 GMC ROYALE 403
>> shift level.
>> Art
>> GMCnet mailing list
>> GMCnet mailing list
Either the start switch is not adjusted up and down the column correctly,
or the pot metal gears inside the ignition switch near the steering wheel
are partially broken. I would try the lower one first.
Salem, Or
78 GMC ROYALE 403
> Thanks
> Art
> starter.
> USE
> BE
> >> JIM HUPY
> >> SALEM, OR
> >> 78 GMC ROYALE 403
> start
> >> shift level.
> started I
> >> Art
> >> GMCnet mailing list
> >> GMCnet mailing list
> Art
Art,
No GMC out here is new. Yes, some have seen better days, but with some love and care, these can be her best days yet.
For a "No Start", there are some prime candidates for investigation.
Assuming you have recently looked at all the connecting cables both power and ground between the battery (and the battery is good), but you cannot
hear the starter solenoid "CLUNK", then lets do the easy stuff.
Down on the steering column is a strange "wrap around" switch. This is where the neutral safety switch is. Before you adjust it, try wiggling the
shift lever. If that works and it does not work when the lever is in the detent, then adjust the switch. Try both at park and at neutral.
Next good bet is the ignition switch this is the long one on the bottom of the column and it can also be out of adjustment. If your ignition key has
been behaving strangely, then this is a real good place to start. If all else fails, get out the wiring diagram and pull the connector off and jumper
between the two that should crank. I was going to give you a hint, but I don't seem to have a wiring diagram in the house...
If none of those get you anything, then pop out the right wheel well and put your body in there and try jumping the starter at the connection on the
solenoid. Nobody said that you can't have a bad starter.
You don't have a sigfile, but there is very possibly someone in striking range that could help you trouble shoot the system.
Let us know.
> I changed the tilt on the searing column and the started engaged. The column was full tilted up. Now it is straight Jim's comment about the
> Thanks
> Art
Well forget the other thing I wrote.
That pretty much means that the ignition switch is out of adjustment. It has screws top and bottom. Put the column where you want it and slide it
until it works. Unfortunately, this is a precursor to the ignition switch rack and pinion going south. Fortunately, those are parts in most store
from car parts store, but it is a tedious job to replace. (Unless you can get to a rally with Chuck Boyd. He can do this so fast it is amazing.) .
Read here
http://www.gmcmhphotos.com/photos/data/6460/start_switch_talk.pdf
Click on block to read
> > Thanks
> > Art
> Matt
Alternator Protection Cable
Your always welcome to call me as I have the luxury of spending my time on
he phone as we have Nick,Gary and Grace handling order desk.
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> > Thanks
> > Art
> glade
> > starter.
> VERY,
> > USE
> WILL
> > BE
> WHEN
> > >> JIM HUPY
> > >> SALEM, OR
> > >> 78 GMC ROYALE 403
> I
> > start
> or
> > >> shift level.
> > started I
> apart
> > >> Art
> > >> GMCnet mailing list
> > >> GMCnet mailing list
Gene, I like the link concept but I do know my MH well enough to under
stand where each of these photos is located. The graphics are great but I
need a caption so I can locate the connection.
Is it as simple as putting a switch between a breaker protected 12 volts
and the starting motor solenoid?
This way you should be able to crank the motor after RPM drops to 0 at 70
MPH without shifting.
Do you need another switch at is the equivalent of turning the key to the
run position?
> > Jim Hupy
> > Salem, Or
> > 78 GMC ROYALE 403
> > > Thanks
> > > Art
> the
> > glade
> > > starter.
> > > >> On Aug 5, 2017, at 4:30 PM, James Hupy
> > VERY,
> YOU
> > > USE
> LOAD,
> > WILL
> > > BE
> > WHEN
> > > >> JIM HUPY
> > > >> SALEM, OR
> > > >> 78 GMC ROYALE 403
> > I
> and
> > > start
> key
> > or
> > > >> shift level.
> > > started I
> > apart
> > > >> Art
> > > >> GMCnet mailing list
> > > >> GMCnet mailing list
> > > GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
*John Phillips*
> Gene, I like the link concept but I do know my MH well enough to under stand where each of these photos is located. The graphics are great but I
> Is it as simple as putting a switch between a breaker protected 12 volts and the starting motor solenoid?
> This way you should be able to crank the motor after RPM drops to 0 at 70 MPH without shifting.
> Do you need another switch at is the equivalent of turning the key to the run position?
> *John Phillips*
John,
Answers are as follows,
Yes,
Yes,
No.
Explanations:
It is that simple, it does however by-pass the built in safeties and the engine could be cranked and started with the coach in gear.
That is completely correct and this is also allows starting at times that might be ill advised.
If the coach is rolling or recently has been, the ignition switch should still be in the "Run" position.
I am finding several wires that go nowhere and terminals with no wires.
looks like lots of stuff has been modified. I bought a terminal to
reconnect the pressure switch on the end of the compressor tank only to
find out that a new pressure switch had been teed into the line at the
compressor. Only one of several loose ends.
> the run position?
> > *John Phillips*
> John,
> Yes,
> Yes,
> No.
> Explanations:
> Matt
*John Phillips*
That's called the PO Follies. Go looking, put stuff back to original, and then go from there, as stuff fails or becomes flaky. I ran my coach onto
its pad this morning, got out and checked. Got back in, no starter action. So you and I are in the same boat :) I'll be checking the neutral switch
and the pushrod when the mood strikes me - likely tomorrow.
--johnny
Braselton, Ga.
On the way to a rally I stopped at another GMCer's place. He was to accompany us the next morning in their coach on the 1000 mile drive. He got in
the coach and it would not crank. Solenoid was not clicking. He said it had been doing this intermittently for the last year or two. We checked the
voltage at the solenoid and nothing. So we cleaned every connection back to the battery. I installed tooth / star washers and anti-ox grease on the
connections. While I was there I installed an second wire on the starter solenoid and ran it up near the battery. Now if during the trip he needed
it, we could simply touch the wire to the positive terminal of the engine battery to get it to crank and be on our way.
Well it has been several years now and it has never failed again. So if you have an intermittent problem, clean all connections and think about
installing an extra wire that can be removed later just in case you might need it in an emergency. A lot of these problems get blamed on the neutral
safety switch. I am not convinced the problem is always the switch.
