Poor Mans DYNO testing
hawk ii
284
Hi all
Now that my GMC is running fine again - I needed some
kind of "benchmark" testing to establish a base line
for my coaches performance. I wanted a means to
evaluate future enhancements and a means of checking
my coach periodically.
Now my solution my not be very el agent - but I belive
it will work for me - and in fact if others will
participate - perhaps we can build a database of
performance timings to more accurately gage which
modifications produce the desired performance
improvements.
METHOD
STANDING START - pedal to the floor - record times for
zero - to 30 / 40 / 50 / 60 / 70 miles per hour
CONDITIONS
Coach Type ---- '73XPD - 26'
Engine/ yr ---- '73/455
heads ---- "j"
ignition ---- "HEI" (springfield)
initial ---- 10 degrees
advance ---- ported vacuum
Gas ---- 87 octane (true gasoline)
load
gas tnk ---- full
propane ---- 90% full
waste ---- empty
water ---- full
cargo ---- 150lbs tools/supplies ?
A/C ---- off
Engine comp---- 170 psi (approx - all cylinders)
road ---- level
air temp ---- 70 degrees (love Florida weather)
vacuum ----
idle ---- 20" (neutral 850 rpms approx)
50mph ---- 16"
60mph ---- 14"
70mph ---- 12"
RESULTS
0-30 ---- 7 seconds
0-40 ---- 11 seconds
0-50 ---- 18 seconds
0-60 ---- 27 seconds
0-70 ---- 40 seconds
Any one else willing to post there results ?????
Pete Papas-->http://members.tripod.com/~mehawk_ii/index.html
. ___________ (MY TOYS) (904)672-0571
./_][__][] []| 1973 GMC M/H 1976 Bi-Centennial Harley M/C
.*O-------OO-* Painted Desert 1979 280ZX Datsun (1 of 1000)
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
Hi Pete,
I printed your data and will use it to compare my results. My old tire
engine is such a dog I don't expect to get anywhere near this but we'll
see.
It may prompt me to get some work done on the carb and distributor.
Nice job! Not everyone will be able to replicate the 70f ambient temp
until spring or summer in some cases!
David Lee Greenberg
200 MacFarlane Dr
Delray Beach, FL 33483-6829
www.gmcss.com/registry.htm
>I'm sorry, but I burn up too much rubber on the road to put my foot
>into it.
>Dean '73-23'GMC (with an extra 175hp).
I guess braggin' rights are in order, here!
David Lee Greenberg
200 MacFarlane Dr
>Hi, Dave, did you find my registration information? Dean
Hi Dean...No, I just looked thru the 99 msgs recv'd now and nothing
earlier. Did you send it via the web site?
David Lee Greenberg
200 MacFarlane Dr
David Lee Greenberg
200 MacFarlane Dr
