Plan C for the air ride system
Bob Dunahugh
2,784
4
3
When I get home. Asses what's in working order. Replace bad components. If the electronic existing system works, or not is fine. As I can't use it anyway as intended. I have an extra set of front control switches that I'll install in the rear bath area. This way I can use a level on the bath floor to get the correct floor tilt for the floor drain in the right rear corner. As this drive in shower has no lip to contain the water at the front drive in area Bob Dunahugh 78 Royale rear bath.
