Phase 2 disc brakes from Applied
Tom Katzenberger
795
287
63
Guys,
I am installing the Phase II disc brake kit from applied. The instruction state that the caliper should be located at the 12:00 position on the rear
wheels, but the brackets will only get me to the 1:30 position (front rear wheel) and 10:30 position (Rear wheel) with still leaving the caliper bleed
valve at the top position.
Do I have older brackets? Is it only the Manny system that has the calipers at the 3:00 and 9:00 front rear boggie arm and rear boggie arm
respectively?
Also, can anyone confirm the disc brake bracket goes on the outside of the boggie arm (axle side) and the trutrack mount goes on the inside of the
boggie arm (behind the boggie arm and axle).
Is there a location I can find a photo?
Thanks for any help.
Tom
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
Tom,
You undi one boilt holding the caliper and rotate it to the position where
it will have the maximum bleed and bleed, then mount it.
> Guys,
> respectively?
> Tom
http://www.gmcrvparts.com
Our new design is clocked so one can bleed it in place.
> Thank you Jim, Will do.
