Paint Shop
john szalay
1,454
We are in the market to paint our 73 Painted desert, there was a
post concerning a shop in Indiana that does good work and knows GMC
does anyone have the name and/or address for that shop ?
This shop would be the closest to us here in Ky.
But looking for suggestions near Kentucky.... really don,t want to
drive the rig too far at this time...
John & Brenda Szalay
Louisville Ky
73 GMC PD
Look in your local phone book under painting for tractor trailers.
> Louisville Ky
> 73 GMC PD
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Just talked yesterday to a GMC owner that was here in Orlando for the same
show as we were and he loves the job that was done by Topeka. He is from
Kentucky and I will get his name as I should be seeing him tomorrow at
Jim's here in Orlando.
Marcus
> John.
> The shop is Topeka Body Shop-----Topeka In-----Ken Ernsberger (219)
> 593-2661 Fax 593 2034 I hear $3,000.00?.......Frank
> >To: gmcmotorhome
> >From: John Szalay
> >Subject: GMC: Paint Shop
> >Date: Sun, 14 Feb 1999 17:57:48 +0000
> >Reply-To: gmcmotorhome
> > Louisville Ky
> > 73 GMC PD
> ______________________________________________________
> Get Your Private, Free Email at http://www.hotmail.com
I need a paint job too.
That $3000 price sure sounds more attractive then the $6,000-$7,000 that
Cinnabar (depending on condition of body & color scheme) quoted me a few
months ago. Their brochure states that this price includes the following
items: "removing all external components from coach, paint and replace.
Original stripe will be removed and all necessary body repair will be
performed. Body molding will be removed and replaced with new molding when job
is complete. The undercarriage will be cleaned & painted. Front engine
compartment will be detailed, window frames will be painted and coach will be
resealed".
Does Topeka does this much work for $3,000? I'm sure Cinnabar does an
outstanding job. However, $3,000-4,000 is a big difference in price!
Richard Waters
'76 Palm Beach
> Marcus
> > John.
> > >To: gmcmotorhome
> > >From: John Szalay
> > > Louisville Ky
> > > 73 GMC PD
You are getting 3 times the work to. Painting the under carriage is not
easy, Detailing the engine compartment is not a joy either.
I think $3000 is to much for just a body paint job, more like $1800-$2500 is
closer.
>resealed".
>Richard Waters
>'76 Palm Beach
>> Marcus
>> > John.
>> > >To: gmcmotorhome
>> > >From: John Szalay
>> > > Louisville Ky
>> > > 73 GMC PD
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Richard,
Considering our paint job, which we did ourselves, cost about $2000 in
supplies (paint, sand paper, primer, etc), I can see how the price can be
high. It really depends what materials are used and on the time spent in
preparation. Spraying paint/primer is the easiest and least time consuming
part of the job. Masking, taping, surface prep, etc are very time
consuming to do correctly.
The best paint job would strip the entire coach down to bare aluminum and
fiberglass/plastic. This takes quite a bit of time, so I would be
surprised if either of these companies do this. The aluminum sections
should be primed with an expensive self etching acid primer (like
Variprime) for maximum adhesion. The fiberglass should be primed with an
almost as expensive filler primer (like Featherfill). Taping and masking
are also a big time killer. We probably put in about 20 hours work (might
even be more) just taping our GMC's major lines (top and bottom of black
and top of gray all the way around).
A paint job is something that should only need to be done once. It is also
the job that, IMO, will get you the most comments on your GMC. Once we
painted our GMC, we started getting comments all the time. People in gas
stations, people in line at Motor Vehicle inspection, toll booth
collectors, etc all started asking about it. Everyone thought it was brand
new and wanted to know where they could get one like it. We had gotten
comments before the paint, but the response we got afterwards was amazing.
In the end, it really all depends on what is important to the individual
GMCer and how that compares with what is done by the different shops.
Every shop will do things a little differently. Comparing paint jobs (and
their prices) done by the different shops is probably the best way to judge
which one is the best for you.
Just my opinions,
Zak
job
>resealed".
>Richard Waters
>'76 Palm Beach
Actually the paint on our coach is not all that bad. The decals are shabby and
faded. Maybe I could get by for a while just by detailing those. I read someplace
that the decals can be painted.
Richard Waters
> closer.
> >resealed".
> >Richard Waters
> >'76 Palm Beach
> >> Marcus
> >> > John.
> >> > >To: gmcmotorhome
> >> > >From: John Szalay
> >> > > Louisville Ky
> >> > > 73 GMC PD
> Tom & Marg Warner
> Vernon Center NY
> 1976 palmbeach
Zak,
Thanks for the honest input. I have been sitting on the side monitoring
the paint posts and have to point to the issues Zak brought up.
Premium grade materials will cost anywhere from $1200-1500. You would be
foolish to paint something as big as a motorhome with a lesser paint, you
DO want to paint it only once.
The big expense in painting is the surface prep., R&R of the accessories &
body work. Another labor gobbler, as was pointed out, is taping. You will
go through 3-4 rolls of blue fine line not to mention mask tape and paper
to line out a 2 color job. It takes a full day working hard to do all the
taping.
I'm religous enough and all of that but I do have to live in modern America
so I have to get more than everyone is talking Topeka gets for labor. A
good job will take 100 hours of labor from start to finish at a minimum,
and there are few short cuts that will not sacrafice quality!
I did the interior on a coach that was painted there, the customer was
pleased with the paint job and it didn't look to bad. They did, however,
have to spend over $400 with me to fill in the water leaks missed in prep.
and the insides of the doors were not painted. The paint was free of trash
though and there were no runs, their shooter is good.
Look, there are many grades of paint finishes and you will always pay for
what you get. I have a 63 split window vette in the shop now. The owner
started out wanting a cheap "cave & pave" squirt on cheap stuff job. After
pointing out that he will devalue his car with such work he understood that
putting the time in to do a good job would be his best bet and I have to
say you should look at a GMC in the same light. I am not knocking a $1500
paint job but unless the laborers are being subsidised by the salvation
army I can't understand how they figure the 100 hours in labor.
I get about $4500 (materials & labor)as a base for a first rate GMC paint
job and I can tell you there are many easier ways to make a living than
doing this! I will guarantee you though that it will be a good job with
everything done right!
Add value to your coach, not just color. Spend the time to do a good job.
Jim Bounds
>Richard,
>Just my opinions,
>Zak
>job
will be
>>resealed".
>>Richard Waters
>>'76 Palm Beach
Jim Bounds / Co-op Motor Works Orlando www.gmccoop.com
Heinz,
If scheduling is set ahead of time, we can usually turn around a coach with
minimal body work in 12-14 working days. Lead time is 4-5 weeks currently.
Availability of specific accessories ie. visor, bumper covers, flares, new
roof AC, etc. needs to be taken into account if any are specified.
Jim Bounds
I did loose one of my body men last week but anticipate hiring a
replacement soon.
>Jim,
>How much downtime for a good paint job?
>Heinz
