Overhead Cabinet Removal
Tom Katzenberger
796
287
63
Hello All,
I am in the process of removing the front clip of my motorhome and replacing it with a donor clip. To do so I need to remove the overhead cabinets and
ceiling in order to access the nuts and bolts which attach the fiberglass cab roof to the aliminum coach roof. I am trying to find out how the
cabinets are attached so that I can remove them.
Does anyone know where to find this information?
Thanks in advance,
Tom & Oki Katzenberger
The cabinets are attached with bolts into expanded nut that are expanded into the aluminum framing. If they just turn when you try to unscrew them you’ll have to try to hold them with pliers.
Bolts go up into the ceiling and also back into the wall.
If the nuts have turned and you are installing the cabinets let me know as I have an easy way to anchor the cabinets.
Emery Stora
77 Kingsley
Frederick CO
> Hello All,
> Thanks in advance,
There are generally 4 bolts per cabinet. 2 are just inside the door
(vertical) and there are 2 on the back wall about 2/3 of the way up at
about a 60 degree angle. I would loosen all 4 first (just a couple of
turns) and then remove the back wall bolts. Then the ones just inside
the door can be removed. It is really useful (almost mandatory) to have
two people to remove the overhead cabinets. One is supporting the
cabinet as the bolts are being removed and the person removing the bolts
can hold the end where the final bolt is coming out. Doing it yourself
without help will lead to the nuts being torqued and twisting in the
frame. I removed mine a while back for a complete remodel and found that
a previous owner had apparently done one of the cabinets by himself;
leaving me with the fun task of trying to straighten and replace the
nut. You have been warned :-)
Good luck.
Gerard Hickey / WTØF IRLP:3067/Echolink:529661
hickey DMR: 3102272
425-395-4554
> Hello All,
> Thanks in advance,
What Gerard said,
Would’ve been nice to have a second set of hands when I was
removing/installing mine. I took the doors off prior as well. Then I cut
some cribbing to put under one end of the cabinet between the counter and
the bottom of the cabinet. Took the bolts over the cribbing first then the
other end.
Sully
Bellevue wa
On Sat, Sep 26, 2020 at 4:38 PM Gerard Hickey via Gmclist <
> Good luck.
> hickey DMR: 3102272
> 425-395-4554
> > Hello All,
> cabinets and
> the
> > Thanks in advance,
Those suckers are heaver than they look.
Gerard and Sully,
Thank you guys so much. The information is extremely helpful. You guys are great.
Take care,
Tom
Sent from Mail for Windows 10
Sent: Saturday, September 26, 2020 8:03 PM
Cc: Gerard Hickey; tomkatz3
Subject: Re: [GMCnet] Overhead Cabinet Removal
What Gerard said,
Would’ve been nice to have a second set of hands when I was removing/installing mine. I took the doors off prior as well. Then I cut some cribbing to put under one end of the cabinet between the counter and the bottom of the cabinet.  Took the bolts over the cribbing first then the other end.
Sully
Bellevue wa
Good luck.
hickey     DMR: 3102272
425-395-4554
> Hello All,
> Thanks in advance,
Gerard and Sully,
Take care,
Tom
To: mailto:gmclist
Cc: Gerard Hickey; mailto:tomkatz3
What Gerard said,
Sully
Bellevue wa
Good luck.
mailto:hickey     DMR: 3102272
425-395-4554
> Hello All,
> cabinets and
> Thanks in advance,
What Sully said. I got a ruined one out that way.
--johnny
Braselton, Ga.
FWIW, I carry a couple of 1/4"/20 studs, about 6" long. When removing cabinets, I install these studs in the rear (angled) holes after removing those
bolts. This helps support the cabinet while removing it. Upon reinstallation, the studs guide the cabinet into position so bolts can be started.
(Can't imagine reinstalling without them, especially working solo.)
JWID, HTH
Rick Staples
Rick Staples, '75 Eleganza, Johnstown, CO
"Advice is a dangerous gift, even from the Wise to the Wise, and all paths may run ill." -Tolkien
That is a really excellent idea I hope to remember if I ever dismount
the cabinets.
Brilliant!
Thank you!
Stu
> removing those
> be started.
> JWID, HTH
> Rick Staples
