http://gmc49ers.blogspot.com/2017/08/the-forever-gmc-onan.html
Damm computers
> This will solve your problems
> On Fri, Sep 28, 2018 at 7:02 AM Steve Southworth
>> > > Per Luis Salas at Walbro, Walbro has run out of LMB parts and can no
>> longer service this carb.
>> > Is there something wrong with the original carb that prevents it from
>> being overhauled? The needle/seat installation is kind of tricky but other
>> > than that I've had no problems rebuilding them with the K1-LMB kit.
>> > Jim Miller
>> The K1-LMB kit did not solve the problem. I am suspecting an internal
>> passage is clogged. Are you aware of information on the internal workings
>> of
>> the LMB? Specifically all the internal fuel and air flow passages. Some
>> are obvious. Others are a mystery. I would also like to know the purpose
>> of the rod in the passage between the lower end of the nozzle and the
>> idle adjustment screw.
>> You are correct the needle/seat and float level setting is tricky. But
>> ya get good at putting that float spring in correctly by the time the float
>> is
>> set.
>> Steve Southworth
>> 1974 Glacier TZE064V100150 (for workin on)
>> 1975 Transmode TZE365V100394 (parts & spares)
>> Palmyra WI
> Gene Fisher -- 74-23,77PB/ore/ca
> “Give a man a fish; you have fed him for today --- give him a URL and
> Alternator Protection Cable
