Onan used Parts Help!
thomas g. warner
1,863
I need a inner battery compartment door. anyone have an extra one?
>Hello group!
>Although I have not worked on my GMC for 2months. Heinz' talk about replacing
>the genset, perked up my ears as to what he was going to do with old one. I
>probably could have used parts from it. Unfortunately, Heinz told me he had
>"donated" it to the installer in an off net e-mail. My Onan still works but
>it was missing the cover plate for the points and the muffler is not the
>greatest. Any body have these used parts laying around?
>Iowa is not out of my sights yet!
>Scott NEHODA'S
>BACK YARD
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Tom
Do you mean the aluminum plate with the circular black foam
rubber thing ? Does it play an important part in the overall scheme
of things ?
MikeB
NS
I believe the black foam rubber thing is a "vent" for allowing the gases to
escape. Mine is flush with the vents in the generator door. And the
aluminum plate gives me something to polish besides the Alcoas.
Chuck
77 K
North Idaho
Tom
of things ?
MikeB
NS
I took mine off a long time ago after I got the removable drawer to
check the batteries. Osburn said it didn't add anything.
Al Chernoff
> Tom
> of things ?
> MikeB
> NS
On Tue, 30 Mar 1999 20:22:15 -0500 (EST) "Thomas G. Warner"
I haven't seen my inner door since 1977 when I removed it to replace the
battery and lost it. I always wondered what it was for??
David Lee Greenberg
GMC Motorhome Registry
and Boston Homes, Inc.
800-827-9989
I have come to the same conclusion dave! Not there so we will ask each other
if we have an extra one. seems like no one has even one.
> David Lee Greenberg
> 800-827-9989
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
My 77 has one. It's not really a door, but an aluminum access panel
attached by 4 bolts. It has a hole in the face, with a foam rubber tube
attached, probably for venting battery gases. The tube is flush with the
vent holes on the generator access door.
Chuck
77K
>In a message dated 3/31/99 5:27:49 PM Central Standard Time,
warner
>writes:
the
>I don't even remember my 77 having such a door, and my 73 doesn't. Where is
it
>and what is it for? If I had one you could certainly have it, 'cause
obviously
>I don't need one.
>Lanier
I made one for my battery compartment on our '76 Eleganza. I used a
piece of sheet aluminum. I cut one corner, drilled the proper holes &
then bent into a z-shape. I cut about 8" off the Onan side of the
compartment side so I could fit a larger battery into that compartment.
The new cover has a longer leg to cover the piece I cut off. I drilled
the two holes where the cover bolts to the body, but the end which is
next to the Onan just stays in place due to the spring action of the
longer z-leg.
Eric Tipton
-----Original Message-----
Sent: Wednesday, March 31, 1999 3:25 PM
To: gmcmotorhome
Subject: Re: GMC: Onan used Parts Help!
will ask each other
one.
Warner"
an extra one?
it to replace the
for??
> David Lee Greenberg
> 800-827-9989
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
It is actually a cover for the battery compartment (next to the generator)
>In a message dated 3/31/99 5:27:49 PM Central Standard Time, warner
>writes:
>I don't even remember my 77 having such a door, and my 73 doesn't. Where is it
>and what is it for? If I had one you could certainly have it, 'cause obviously
>I don't need one.
>Lanier
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
