> Worked on the beast (Onan) today. To bring you all up to date....almost
> overnight it went from running like a clock to belching, shaking, not running
> real good. Cleaned up carb, recalib. the float, checked fuel supply, fuel
> filter. I am speculating it's an ignition problem. (Althougth I will check
> compression tomorrow.) So.....who sells points, condensers, coil, plug wires,
> sort of a care package? Cinnabar? Jim Bounds?
> HELP! Larry Nelson, PB 75, sunny southern MO
Larry, If you have access to a Camping World they will have most of the
parts you will need they sell tune up kits , oil filters , air filters
and even the circuit control boards for the Onan generators. I had about
the same problem with mine. The points were stuck open and my control
circuit board was bad . The board was about $190. The generator would
only stay running as long as I held the starter switch down but once I
put the new board in it ran fine. I hope this info can help you, Brad.
