Onan remote problems
al chernoff
737
Emery, that was one of the suggestions given by Duane Simmons. By removing
1,2,3 you can test the unit without the remote. Good call. What a great bunch
of brains we have in this group.
al
> This is just for information purposes. Walter Drew and I were working on his
> Onan a couple of days ago. The inside remote switch wouldn't work at all.
> The switch on the Onan would crank it but not start it. By running a jumper
> from terminal 11 to terminal 9 we could get it to start and run properly at
> the Onan control panel. We substituted my Onan board which we knew ran right
> and still had the same problem. After several minutes of searching we found
> that by disconnecting the three wires from the Onan circuit board that go to
> the remote (terminals 1, 2, 3) we could start it from the Onan without having
> to jumper 11 and 9.
> We then checked the three wires going to the remote with an ohmmeter and
> found that number 2, the ground wire, was shorted to the frame or body
> somewhere along its length. We decided to run another wire and after hooking
> it up found we had fixed the problem. It now starts both from the remote and
> from the Onan. The short had the same effect as holding the remote switch in
> the off position.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
I wish I had been there to these two white haired gents playing with
their GMCs. Aaaah, it my heart good.
Jan and I had lunch with Emery and the Drews while we were in anta Fe and
they are great folks...but I probably didn't need to tell you all that,
did I??
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
NEXTEL Mobile: 561-262-0233
