Onan ran out of gas - how long to try starting
Deb
358
6
3
Next problem - The driver of my old coach (just sold and on it's way across the US to the east coast) lost the alternator belt - belt is still there
and a mechanic has come out to put it back on.
He was running on the Onan to charge the coach battery, and the Onan ran out of gas (got below 1/4 tank). It has had no starting problems up to this
point - fired right up first shot today when we needed it.
Question - how long will it take of attempted starts before the air is out of the Onan fuel line?
Once the alternator belt is back on it won't be a huge immediate issue, but it is so nice to have as back-up (case in point!)
And I can't remember - if he wanted to use the on-board switch and disconnect the starter just to prime the system, or by-pass it on the board, what
is an easy way for this fellow to be able to do this?
Deb McWade
Logan Lake, BC, CAN
GMC Alumnus
It's Bigger on the Inside!
A jumper wire between 5 or 7 and 11 on the Onan control board will energize the fuel pump.I am sure that someone here will jump in and verified the correct terminals to connect.
Sent from my iPhone
Nelson Wright
Orlando Fl.
> Deb McWade
> Logan Lake, BC, CAN
> GMC Alumnus
After sitting for a while, and 2 or 3 more attempts, she is running like a top and charging the coach battery! Told him to make sure he always stops
for gas well before 1/4 tank anyway. Alternator belt is toast - got chewed up in the other pulleys. But the Onan should get him to his destination
tonight.
Deb McWade
Logan Lake, BC, CAN
GMC Alumnus
