Onan pro's say... "Since you've got it pulled, you aught to ______
david horowitz
47
I've got the 6Kw pulled from my 1975 Avion so that I can clean and refurbish the genset compartment.
I'll be doing all the normal service items, but wonder what if any procedures/upgrades/modifications are best done with the unit pulled.
Thanks for any suggestions!
Dave
David del Rio - 75 Avion - Raymond, CA
I'd check every wire from the Molex connector to its termination, looking for scuff marks or broken insulation and replace any that are suspect.
Then either sleeve them or ty-rap them off places where they're abrading when the set runs.
--johnny
Braselton, Ga.
"Sometimes I wonder what tomorrow's gonna bring when I think about my dirty life and times" --Warren Zevon
You might consider changing your generator to allow propane operation. I've attached a link Jerry Work's presentation to the GMC Western States in
Coos Bay last month with lots of reasons why this makes sense. I've converted mine using his instructions and the kit he designed with US Carb and it
works well.
http://gmcws.org/blog/?p=4335
Jack Christensen - K6ROW,
'76 Glenbrook/Clasco - "The Silver Bullet",
Sebastopol, CA
> Dave
Dave
Here is an example of an extreme make over...
http://cathy-ron.com/GMC%20Generator.html
Dennis
Dennis S
73 Painted Desert 230
Memphis TN Metro
Dave,
So who are the experts????????????????????
On Sun, Nov 13, 2016 at 5:21 PM, David Horowitz
> Dave
Applied/GMC, Fremont,CA
http://www.appliedgmc.com
Disassemble and clean the drawer slides.
Use a dry lubricant.
On Sun, Nov 13, 2016 at 10:31 PM, Jim Kanomata
wrote:
> Dave,
> > Dave
> Jim Kanomata
> jimk
> 1-800-752-7502
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
You might want to do the Petronix ignition upgrade...though that can be done with the genset in place. JWID
Larry
78 Royale w/500 Caddy
Menomonie, WI.
the experts are HERE jim... you jim, and all YOU wonderful people have provided exactly the information i needed.
i can't thank each of you enough!!
info and piix about what i've done to follow....
sincerely,
dave
Since no one else mentioned it, you might want to consider pulling the heads and doing a decarb. Its pretty straightforward
76 Glenbrook
There are few things one should consider:
The primer switch mounted inside to pre prime the carb so one does not need
to crank but short burst.
The cooling air deflector to keep hot are from gen will not be pulled in to
cool. Also keep the air from blowing directly and creating dust which will
be brought up and damage the armature and shorting the life of the air
filter.
Rubber seal around the Oil filter so there will be more air circulating
through the cooling fins.
Improve the weak ignition system with a Pertronix system that will wake up
the uit. You need to remove the cover and place a magnet on the flywheel
for signalling.
Also there is a more expensive MSD ignition system with multiple spark that
will also wake up the unit, but does not require any disassembly.
Also tighten the Oil filter adapter.
Replace the starter bracket with the steel bracket as they do break.
Also replace the origional bridge rectifier with a newer one as they are
bullet proof.
On Mon, Nov 14, 2016 at 9:30 PM, David Horowitz
> sincerely,
> dave
