Thanks, a few questions.
#1.. how long should the fuel pump prime-button be depressed while priming before starting?
#2.. Is it advised to also depress the primer button while starting the APU?
#3..Once the generator is started and up to speed, does the generator suction feed fuel or does the electric fuel pump run while the generator is
running?
Thanks, Scott.
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi. Alex Ferrera
installed MSD Atomic EFI
Houston, Texas
running?
Thanks, Scott.
Scott Nutter
Houston, Texas
