Onan gas use
dean hanson
256
Has anyone actually measured how much gas per hr an onan uses running one
A/C?
Dean C. Hanson 75 Avion 6KW
P.O.Box 2096
Fremont, Ca. 94536
(510) 657-9600
> Has anyone actually measured how much gas per hr an onan uses running one A/C?
Dean,
Yes, I have. And it was exactly that and also unloaded.
This is for a BF (4kW) but as the two are so alike, I would expect little difference.
1 - 15500 Carrier AC running flat out it burned just under 0.5GPH.
2 - At a sustained speed unloaded it burned 0.22 GPH.
These are averages of multiple runs and on different days.
Altitude was 623'MSL.
I did not correct to sea level or for ambient conditions. (I could, I just didn't care that much.)
Onan ru time
> one A/C?
> Dean,
> difference.
> Matt
Alternator Protection Cable
